Текущее время: 08 дек 2025, 15:52
 Заголовок сообщения: Pro Micro Serial Communication Issue
СообщениеДобавлено: 08 апр 2018, 16:02
Hi,
Using a different serial monitor (Realterm) showed much the same results, except that the freezing was handled better and I just kept seeing the incoming serial data, suggesting it's an issue with the Pro Micro or the Pro Micro drivers.The LED on the board doesn't light up when I send any commands, suggesting nothing is reaching the board to begin with.The sketch itself is pretty straightforward. It constantly outputs sensor values (everything seems correct here) until I send a command, when it should stop and send something else. The Pro Micro doesn't seem to be receiving the command and just keeps outputting the sensor values. Fairly sure it's not a code issue though, given the results above and that the code works flawlessly on a Nano.What can I do to further troubleshoot?
Please help.
I didn't find the right solution from the Internet.
References:-
https://forum.sparkfun.com/viewtopic.php?t=41515
Thanks
